I have set my base map in Survey123 to my custom (tiled) basemap, I would like for the report to also use that same basemap when it generates the report as opposed to the esri default.
Hi Noel,
Yes, you can specify a basemap in the template- refer to the 'Geopoints' section of Print survey results—Survey123 for ArcGIS | ArcGIS
