Can I override the 'choice_filter' based on a answer to another field?
1085
09-05-2018 01:36 PM
NoelPerkins3
I have a choice filter setup on several fields for our normal daily operations, but when we switch to emergency #operations I would like to override the choice_filter so instead of the drop down lists a user can type in the name during an emergency we may non-normal operations personnel filling in positions. First line on the form is to choose Normal Operations or Emergency Operations. Debbie Murphy
JamesTedrick
Esri Esteemed Contributor
Hi Noel,
Yes, this can be done by having a comparison in the choice_filter to the Normal/Emergency question.  See the attached example
JamesTedrick
Hi Noel,
NoelPerkins3
Hi James,
Thanks I did not see an attachment, although that could be me.
DebbieMurphy
I downloaded it and sent it to you in an email Noel.
NoelPerkins3
Thank you
