Can I make my map view window bigger in the web app version?
566
08-14-2019 09:49 AM
MarkButler1
I'm using survey123 to push out a survey using the web app.  I built it in the beta version of survey123 connect so I could do a geoshape.  The resulting map window view is smaller than i would like, hard to see.  Can I make it bigger somehow?
Follow-up question, how can i use the imagery hybrid basemap in this same map window?
JamesTedrick
Esri Esteemed Contributor
Hi Mark,
A small enhancement coming in the next (3.6) release of Survey123 Connect and the Field App will let you set the height of a map question- look for it very soon!
