Can I force a repeat to have the first record?
549
06-23-2020 11:02 AM
DougBrowning
MVP Esteemed Contributor
I have a repeat inside of a repeat and it will not show the first record.  I have the appearance blank per the help but it still is showing.  I tried to set required on the repeat itself and I get a star but it still allows me to go on.
I want to require at least 1 item in the nested repeat.
Want
How can I force that first record to show.
Thanks
SMauri
Hi Doug,
have you set any preference in field "appearance" for that question?
From https://community.esri.com/groups/survey123/blog/2020/04/09/survey123-tricks-of-the-trade-repeats
Cheers
Stefano
DougBrowning
I have nothing in appearance just like the helps says.  That is what I meant in my post.  My guess is that it is behind a if.
thanks
