Can I draw circles with Geotrace?
495
09-17-2020 08:53 AM
KerryKang
Occasional Contributor III
Hello all,
I have a use case that geometry needs to be represented as circles (new data collection). I just checked the sample form, but it does not look like supporting drawing circles. Is there any work around?
Cheers,
Kerry
Shwu-jingJeng
Hi Kerry,
Yes, you could specify the method=sketch and use smart shape option to draw a circle:
Here is the online doc explaining the details:
Geotrace and geoshape—ArcGIS Survey123 | Documentation
KerryKang
Hello Shwu-Jing, thank you for the information. Is it possible to do that with 'Geoshape' instead of Geotrace? I hope to get the circle shape as polygon features. Also I was wondering if I can draw a circle by passing x, y, diameter values (maybe using concat?), not asking user to draw it on the map directly.
Cheers,
Kerry
