Can I bulk upload csv data into existing form on Survey123
4672
08-16-2017 07:40 AM
Oliver_Burdekin
Occasional Contributor II
I have survey data from an old survey (not created nor collected using Survey123). If I would like to port this survey over to Survey123 I believe I can upload the form itself as it was designed in XLSForm. However, can I bulk upload the survey responses we have already collected? I realise the format is different but can convert it to match the csv output of Survey123 data.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Olivier,
This can be done most easily via ArcGIS Pro - that is simply using the Append geoprocessing tool and specifying which field in the original table matches which field in the feature service that is created for Survey123.  A script could also be created using Python or other language and working with the REST API directly (the appropriate operation is ApplyEdits -  ArcGIS REST API ).
Ness2
New Contributor III
Hi James,
I am attempting this process however the Append tool in Pro is demanding a featureclass, table or raster as the target data set.  It is not accepting feature services.  Any suggestions?
JamesTedrick
Hi Vanessa,
That's interesting- I know that I've appended to a feature service before in Pro.  Could you try using the Append tools in ArcGIS Online - see What’s new with hosted feature layers: Getting to know Append Part 1 (December 2017) | ArcGIS Blog?
