Can custom urls be used with offline maps in Explorer?
1223
01-04-2018 12:20 PM
TylerGrosshuesch2
Is there a way to use the custom url scheme from an offline map (.mmpk) in Explorer? I want to use the custom url to pass data from features in the map to a survey form for asset inspections. I tried to set up the popup in Pro like I did in a web map, but Pro didn't recognize arcgis-survey123:// as a valid url - the Apply button stayed grayed-out like in the picture. It worked fine with a url beginning with http.
survey123 url won
MarkBockenhauer
Tyler,
You will be able to do this with ArcGIS Pro 2.1   , which should be available for download within the month.
ArcGIS Pro 2.1 Popup hyperlinks will suppor the following URIs
"http", "https", "mailto", "iform", "tel", "flow", "lfmobile", "arcgis-navigator", "arcgis-appstudio-player", "arcgis-survey123", "arcgis-collector", "arcgis-workforce", "arcgis-explorer", "arcgis-trek2there", "mspbi"
Mark
by Anonymous User
Not applicable
Hi Tyler,
It looks like this could be a bug with Pro and the URL field in the Pop-ups box. You would be better asking this question in the Pro GeoNet forum or raising it with Esri Support so it can be addressed.
Regards,
Phil.
MarkBockenhauer
Tyler,
Mark
TylerGrosshuesch2
Thanks Mark. I'll give it another try in a few weeks.
