Can a Survey123 text field make the Android app keyboard only enter upper case letters?
268
09-03-2018 01:07 PM
RogerFarmer1
Can a Survey123 text field make the Android app keyboard only enter capital letters?
We have electrical distribution equipment that is given an 'earth' (ground) or FacilityID that always has a capital letter. When this ID is entered in the app, can the keyboard automatically have caps lock on?
Reply
BrandonArmstrong
Hi Roger,
I think that applying an 'Input Mask' may give you what you are looking for. By simply placing the '>' character along with a number of 'X's' (placeholders) into the input mask of the body::esri:inputMask column of your XLSForm, it will force all input characters to be uppercase.  So for instance, if you had a US License Plate # that you wanted to be all capitals and knew that it was 7 characters long, you would place >XXXXXXX into the body::esri:inputMask column of your XLSForm.
More can be found here Esri custom columns—Survey123 for ArcGIS | ArcGIS
Best,
Brandon
BrandonArmstrong
Hi Roger,
Best,
Brandon
