Can a survey creator stop survey 123 from using device location
558
07-19-2021 01:04 PM
PrachiPatel
As part of development approval process I have created a survey through Survey123Connect. I have a question on project location where the submitter creates a geopoint of the project location. This is a required question. Unfortunately, if a submitter does not answer this question, survey 123 defaults to using the device location instead of asking the submitter to answer the question. As a survey creator, how can I get Survey123 to stop using submitter device location and make them answer the question?
DougBrowning
What I did was set a default of 0,0 then set it to required.  That seemed to work for me.  You could also set a constraint to not be 0.
Hope that works for you.
DougBrowning
PrachiPatel
Yes, setting the default as 0,0 made it work
