Calculations using Survey123 form in browser
9504
48
08-03-2018 09:03 AM
TaylorRobin1
When filling out a Survery123 form using a browser, my calculations from Survey123 Connect do not go through. On my mobile device and the desktop app they work. Is this know issue? Is there something I can do to get this to work on the browser?
by Anonymous User
Not applicable
Last question: does this (or any Arcade function) utilize credits? Thanks for your help, James.
by Anonymous User
Not applicable
Nevermind. I answered my own question!
ChaimSchwartz
Are there plans to add the area() function to the web form?
Edit: Just noticed the area() function seems to work when the webform is embedded in Experience Builder!
DSIProvince_Nord
Hi there,
James Tedrick, I have also a similar problem witrh calculate field not working in web form.
My calculation is a nested if based on four select_one questions (also nested in the form) :
if(selected(${identification}, 'oui'), ${espece}, if(selected(${carapace}, 'dermochelyidae_luth'), 'luth', if(selected(${carapace}, 'cheloniidae_olive'), 'olivatre', if(selected(${carapace}, 'cheloniidae_5'), 'grosse_tete', if(selected(${ecailles_prefrontales}, 'prefrontales_1'), 'verte', if(selected(${ecailles_prefrontales}, 'prefrontales_2'), 'imbriquee','indeterminee'))))))
It works fine in field app but does not in web form.
Published from Survey Connect 3.6.137 and tested with web form "as is" 3.6 or "as latest" 3.8.
Is this a known issue ?
JamesTedrick
Esri Esteemed Contributor
The issue with your form is the use of property('username'), which has been deprecated in favor of the username question type.
DSIProvince_Nord
Hi James,
Thank you so much, now it works fine using the username question type.
Strange that half of the survey used to work with the property('username') and kept stopping at the Calculate field... but finally it had nothing to do with calculation
GrantHerbert
Occasional Contributor II
Is there a place to see what is supported in the web browser for calculations?
LuisMartinez3
I am having the same issue as most above...with an additional minor one. I am getting the NaN in my web form calculation when adding to string fields. I am adding values from a selected field and a text field using formula
${eclid2} + "-" + ${eclid}. It works well in app and Connect but in browser I get NaN. Am I missing something?
Also, when using the likert appearance, I get a "image" icon below the text. I have seen this before and may be something to do with the xls form, but not sure. Any ideas?
select_one eclincidentnmbrEmergency Classification Level  esriFieldTypeString
texteclidEmergency Classification IDEnter record number and year (25-20) esriFieldTypeString
calculateeclid2Emergency Classification ID2 if(selected(${incidentnmbr}, ‘UNE’), ’Unusual Event’, if(selected(${incidentnmbr}, ‘ALE’), ’Alert’, if(selected(${incidentnmbr}, ‘SAE’), ’Site Area Emergency’, if(selected(${incidentnmbr}, 'GE’), ’General Emergency’,’Other’))))esriFieldTypeString
calculateeclcalECL Calculate ${eclid2} + "-" + ${eclid}esriFieldTypeString
texteclsubstrEmergency Classification Number ${eclcal}esriFieldTypeString
NaN Screenshot
DSIProvince_Nord
Alternatively you could use the concat() function :
concat(value1, value2, …)
Returns the concatenation of the string values.
concat(${question_one}, ' and ', ${question_two})
regarding the Likert issue, it may have something to do with this :
Several appearance types available in Survey123 Connect are instead available as separate question types in the Survey123 web designer. This includes Multiline Text, Dropdown, and Likert.
(Quick reference—Survey123 for ArcGIS | Documentation )
LuisMartinez3
Dude, I cannot thank you enough. I looked at the quick ref guide and guess with all the text I've been staring at I didn't even see that. It works perfectly! Appreciate the quick response.
Also, for the image icon appearing under the text, the field type was set to text, removed it and went away!
