calculate with a javascript function to it self field line
213
03-02-2023 02:33 AM
GrégoireCATINEAU
New Contributor III
Hello,
I would like to apply a uppercase javascript function on the field that is on the same line than the input field to force uppercase input.
pulldata("@javascript","uppercase.js","touppercase",${C22_ENS})
the field 22_ENS is on the same line, but it's don't work ...
IsmaelChivite
Esri Notable Contributor
Try the following:
  • Add a text question to get the original text from the user
  • Add a separate question (a calculate for example) and calculate with your touppercase function
  • You can set the bind::esri:fieldType column of the first question to null if you are interested in getting that original text in your feature layer
If your calculation in field 22_ENS uses the value from field 22_ENS, you will be creating an endless loop (recursive). That is not allowed.
IsmaelChivite
Try the following:
GrégoireCATINEAU
New Contributor III
Thank you very much Ismael.
