Calculate location in geopoint from pulldata did work, republished in 3.11 and now it doesnt.
1567
01-25-2021 03:42 PM
JulesBarrett
The calclocation will only work in field app not browser.  It did work in previous 3.10 v.  I can see in the form the location is found, but it will not populate to the point.  I can only have this survey browser based as it is a public survey.  Here is a slimmed down version of what I need to work.
Thank you so much.  🙂 J
IsmaelChivite
Esri Notable Contributor
Hi @JulesBarrett
I published your survey with 3.11 and tested it in the web and field apps. It worked fine for me.
I also tested the survey in 3.12 Beta and worked as well.
JulesBarrett
I am sending the original .xlsx, as I republished with the same results. My point still lives at 0:0. I have published in 3.11
Could you tell me please what I am doing wrong?
Thank you
Julie
