Calculate a field based on how many questions have been answered "yes"
254
07-29-2019 01:20 PM
SebastiánArdila
New Contributor III
Hello,
I have a survey with a series of yes/no questions, the  user needs to know at the end how many questions have been answered  "yes". Is there a way to do this?
DougBrowning
MVP Esteemed Contributor
You need to make a second calculate field and then use a if(field=yes,1,0).  Then make sure to set the bind::type column to int.
Then your final one would be field1count + field2count + ...
Yep its is a pain if you have lots of fields.
