Bug Report - similar to BUG-000098492
194
06-20-2018 04:33 AM
DeonLengton
This bug is related to BUG-000098492 - Default date and time values do not auto-populate when using repeats in Survey123 for ArcGIS.
I have discovered that a variation of the bug mentioned above (fixed with Ensiheim-meteorite-strike-day-release-19 release) is still present.
The following workflow reproduces the bug:
  • Add an integer field (used in the repeat's relevant expression)
  • Add a date field and a time field outside of a repeat. Default them to today() and now() respectively
  • Add two similar fields inside a repeat. Default them to today() and now()
  • Add a relevant expression to the repeat (integer field = 1 for example)
Execute the survey:
  • Only the date and time fields in the main survey get’s defaulted as expected
  • Date and time fields inside the "related" repeat does not get defaulted when the relevant expression is true (when 1 is entered into the integer field)
Reply
Philip-Wilson
Esri Frequent Contributor
Hi Deon,
BUG-000098492 was fixed and closed as part of our 3.0 release a few weeks ago. We made several fixes and improvements to defaults, calculations, relevant and repeats in this release. Can you please test with 3.0 and let us know if you are still experiencing the issue above.
Phil.
Reply
