Blank Screen on Analyze Results
1154
04-13-2021 09:42 AM
DevinLavigne
I have a few surveys where the data is not loading when I click Analyze results. I get only a blank screen.
I have set permissions of the survey results below to Everyone
https://arcg.is/1vCzGv0
There are 433 records. I can view the information through the Data tab, but see nothing under Analyze. I am seeing this behavior on a several surveys.
DevinLavigne
Thanks for pointing me in the right direction. Adding this to the query string - whether it is analyze or result works ?filter=(0.objectid%20isGreaterThan%200)
TMaddio
I had this happen in the data tab and the feature reports.  It ended up being this bug that has to do with the first field in the survey being a note field in a pages formatted survey.  This also references the Analyze functionality:
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzODQ3NQ==
I added a hidden field and things started working.
This post was helpful:
https://community.esri.com/t5/arcgis-survey123-questions/data-not-loading-on-data-tab-in-survey123-o...
DevinLavigne
