Basemap support in Survey123
960
07-16-2017 09:36 PM
JacobHechter1
Hi.
I work for New Plymouth District Council in New Zealand.  We would like to use Survey123 as a data capture tool.  All of our ArcGIS Online basemaps are in New Zealand Transverse Mercator projection.  However, Survey 123 only seems to support Web Mercator basemaps.  Will the functionality to use basemaps with projections other than Web Mercator be available in later releases?
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Jacob,
Thanks for the enhancement request.  I've added it to the list of enhancements to consider.  You might want to check ideas.arcgis.com to see if there's an idea already logged or place one there yourself- it helps us gauge the level of interest in a particular feature.
