Autopopulate questions in Survey123 Connect
1410
04-02-2023 03:53 PM
AndrewCastilloTBSL
Hi everyone,
I am creating a survey in Survey123 Connect, One of my questions in my survey "Name of School" is a dropdown list of school names from a column field called "Names" from a csv. file in the media folder called "SchoolNames".
I have following question in the survey called "District Name" if you can see the screenshot above the csv file in my media folder also has a column field called District, basically the name of the districts the schools are in.
 I want to configure the survey so that when you select a school it automatically populates the school's associated district.
How do I do that?
and can it only be done in a text type question or it can also be done in a select_one choice type question as well?
I also attached my media csv file and the survey XLS form if that provides better context.
ChristopherCounsell
MVP Frequent Contributor
ChristopherCounsell
