Autocomplete search not pulling options for downdown list
1477
10-20-2023 03:35 PM
RutledgeNicholas
I am trying to pull a list of Case IDs into a dropdown menu using Survey123 Connect.
I've inserted the following info in the appearance column of a "select_one list_caseID" row:
autocomplete search('list_case_id?url=https://services8.arcgis.com/euhkr1dAJeQBIjV0/arcgis/rest/services/service_fb0410d92ff74e75981d175d7...')
The dropdown field is blank and even when I type in the field, no results populate.
Can someone help me with this?
Jim-Moore
Hi Nicholas, thanks for providing your XLSForm.
Currently the name and label for the list_caseID choice list are caseID and Case ID, respectively. Could you please try making the name and label for the list_caseID choice list the same value, i.e. caseID (assuming this matches the field name in the feature layer exactly)?
Hope this helps. Best, Jim
Jim-Moore
RutledgeNicholas
Thank you @Jim-Moore. I changed all my names and labels to "caseID" instead of "list_caseID" and this seems to have fixed the issue.
Thank you again!
RutledgeNicholas
@Jim-Moore
One more question. Is it possible to do a choice_filter when pulling an external list like this as well? I want to filter the caseID options that show up for specific radioBrands selected in this XLSForm?
Jim-Moore
Hi @RutledgeNicholas glad to hear you got it working.
Regarding filtering the choices - instead of using choice_filter, you can use the optional search/filter parameters in the search() expression itself, as described here:
Dynamic Choice Lists using Search Appearance - Esri Community
