Auto select Multiple choice from other answers
1512
05-04-2022 09:02 AM
PanGIS
Hi everybody!
I am trying to complicate my life 🙂 and I want to get the following:
I have a multiple choice that will be eventually hidden.
This multiple choice is fed by other questions.
I would like to get all Options selected in the "Option needed" question, but it selects only the fist option.
If I select the second and the third choice, then it will select the second only.
This is the calculation:
if(selected(${Choice1},'Choice1'),'Option1',
if(selected(${Choice2},'Choice2'),'Option2',
if(selected(${Choice3},'Choice3'),'Option3','')))
I am not able to figure out how to solve it.
Thanks!
IsmaelChivite
Esri Notable Contributor
Hope this helps. XLSForm attachedHope this helps. XLSForm attached
See attached XLSForm example
IsmaelChivite
PanGIS
Thank you for this late reply but I worked, thank you! 🙂
