Auto capture geopoint location of survey
936
06-25-2024 11:47 AM
CameronLacelle
Is there a way I can get my survey123 to automatically capture the geopoint field based on the location of the device used to submit the survey? I want this to be done in the background so our end user doesn't have to manually click a point on the map, so we can get the survey locations for what we are using for asset inspections. How can I accomplish this in the XLS form?
abureaux
MVP Frequent Contributor
That is the default behaviour of a geopoint question. If you set it to "click to locate" then it requires manual input.
If you are talking about the browser, there will be a pop-up to allow location services. That cannot be avoided.
abureaux
CameronLacelle
Thanks, that's good to know it just auto locates.
