ArcGIS Survey123/Power Automate - Dynamic schema response from API 'survey123' operation 'GetWebhookPayloadSchema' is too large
3884
8
03-04-2021 08:10 AM
LJackson29
I am trying to add a Survey123 survey to a Power Automate workflow to send an Outlook email when a survey is submitted. This is a workflow that I had working for a year and it stopped working about 2 months ago. I deleted the old workflow (unfortunately) and I reconnected to the Survey123 connection per https://support.esri.com/en/technical-article/000022795
and am creating a new workflow.  I am able to add my survey, but when I add the Outlook send email step, I  cannot see dynamic content, and when I try to save the flow, I get the following error "The dynamic schema response from API 'survey123' operation 'GetWebhookPayloadSchema' is too large, only schemas with at most '1024' properties are supported." The error makes it sound like there are too many fields, but there are only about 300 fields in the survey. I tried adding other shorter surveys instead and was able to do that. Anyone have any ideas - Many thanks!
cbolen
Any solution found? Experiencing same thing.
LJackson29
I have not found a solution. I posted here and on the power automate board and have gotten no responses.
abureaux
MVP Frequent Contributor
Not sure if this will help as our problems seem different, but I'll give it a shot.
I have a very large survey (well over the 1024 soft limit). This was causing Power Automate to give me an error (same as yours) and prevent me from saving.
I set Include submitted record to No in the Trigger and the flow saved instantly (You can also edit the webhook in the S123 web page):
LydiaCarey
When I set include submitted record to No mine doesn't end up triggering at all
abureaux
Did you remember to update your survey after setting that to "no"?
Any changes you make to the flow trigger "When a survey response is submitted" (e.g., toggling "Include submitted record") will require a survey update. Without that update, the flow will not trigger.
I did a quick test to see if anything changed, and both runs (one each for "Include submitted record" set to yes and then no) worked as expected after applying the appropriate survey updates.
Michael_VanHatten
Was there a solution or work around that worked for you? I have the same error message and if I set Include submitted record to No in the Trigger, I get some of the survey123 feature data like portal info and user name but none of the information from the survey questions. I am new to Microsoft automate, I have used Integromat in the past and in my experience Integromat works much better. My new job works in the Microsoft cloud so I have to use this.
LJackson29
I still have not found a solution to this problem, and had to remove my notifications. I believe it is related to the length of the survey. I have a couple of shorter surveys and the notifications still work for those, but they do not work for the longer surveys.
abureaux
I just looked at the initial response for my large survey, and I can see all my data and I am able to call on these dynamic content:
What is the issue you are seeing exactly? Maybe I am misunderstanding.
