ArcGis Survey 123 Connect - likert (vertical) position not working.
1186
09-30-2021 07:27 AM
CrisjovanoGumaraes
New Contributor II
Likert apearence not working in vertical position, only horizontal.
Its works fine in web form in device (phone) visualization mode. But this functionality in Survey connect (XLS Form) after published to be used in app not works.
In attachment is what I need
JamesTedrick
Esri Esteemed Contributor
Hi @CrisjovanoGumaraes ,
The Likert appearance is behaving as we expect - Likert questions published from Survey123 Connect display in the web app the same way as Likert questions published in the Survey123 web designer.
Is the concern that Likert questions are always horizontal in the field app?
Anneka_France
Occasional Contributor III
Is it possible to present a likert in the vertical position in the web or mobile app to allow more choices or longer labels?
Anneka France
Technical Manager at The Rivers Trust
CrisjovanoGumaraes
New Contributor II
Yes. The questions are always horizontal in the field app. And I can not change it. How is it possible to rotate it ? Any parameter ?
