AppConfig PortalURL
853
9
07-11-2018 08:26 AM
PraeceConsulting
I'm trying to use AirWatch to automatically configure my Portal in Survey123. Setting the appConfig key "portalURL" works great in Collector and Workforce, but doesn't seem to work in Survey123. Is there a corresponding appConfig key in Survey123 that will automatically fill the portal url for users?
Thanks!
Philip-Wilson
Esri Frequent Contributor
Hi Praece,
Survey123 does not currently support appconfig via MDM solutions such as AirWatch, however we are working on implementing this feature in a future release. We will kepe you updated when it is available.
Phil.
PraeceConsulting
Thanks!
GaryBowles1
Occasional Contributor III
Philip,
Any update on when this might be available?
--gary
TL2
You can hard code it using AppStudio.
Philip-Wilson
Hi Gary,
We are aiming to have the PortalURL config supported in a release later this year, it did not make the cut for the 3.5 release before the UC, but it is in progress.
Phil.
AdrianIsdahl
Any news on when this wil be available, Philip?
Philip-Wilson
Hi Adrian,
We are currently working on this feature and planning for it to be released later this year in an upcoming release, hopefully that should be around June/July.
Regards,
Phil.
MickHuska_Jr__ALLETE_
New Contributor III
Any update on the timeline?
Philip-Wilson
Hi Mick,
Yes, good news, support for AppConfig and portalURL will be part of our upcoming 3.10 release, due out in a few weeks. You can test it out with the current 3.10 RC builds available on Early Adopter Community, and described in the following AppConfig documentation on EAC.
Regards,
Phil.
