allowUpdates=True is only working for some records
1328
07-05-2021 04:14 AM
mwehbi_unicef
I trying to edit the repeat in my inbox. I used the syntex allowUpdates=True and it works for some sites only. All new sites after the update is not working and not showing any data in the repeat.
by Anonymous User
Not applicable
Hi @mwehbi_unicef,
Are you using the "query" syntax also, this is required to display the existing repeat records in Inbox. Also I notice you are using "True" instead of "true", can you try lowercase. Please refer to following doc for supported syntax: https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm#ESRI_SECTION1_80CFF...
Do the sharing permissions of the feature layer and repeat layer allow updates?
Also, are you able to share your xlsxform and supported media so we can take a closer look at your survey.
Regards
Phil.
mwehbi_unicef
Thank you @Anonymous User  for your reply.
Yes sure, i tried all the syntax including query, small letter, capital letter. The main idea is that it is working for some records normally but all new records it is not working.  Can you please provide your email so i can share the xls and the credentials with you.
by Anonymous User
Not applicable
Hi @mwehbi_unicef,
I sent you a private message with my email address.
Phil.
mwehbi_unicef
Hi @Anonymous User
I shared the xls and credentials by email. I hope we can find the main issue. Thank you for your support.
P.S. all records before specific date (24June if I am not wrong) are working well. all new indicators didn't work. You can add records but adding the name as TEST so i can delete later.
