Allowed to edit Read only field
1142
05-04-2017 11:05 AM
MariaNieves
I am having an issue with read only fields. I have a select_one/read only field with a default value and when i create or edit a survey, I am able to edit that field. Is this expected behavior? I checked both the iOs and Windows version of Survey123 2.0.
Maria
JamesTedrick
Esri Esteemed Contributor
Hi Maria,
This is a known issue with select_one questions at this time.
by Anonymous User
Not applicable
Hi Maria,
Read-only functionality on select_one and select_multiple question types has been implemented and will be available in the next release of Survey123, version 2.4.
Regards,
Phil.
