Adding target="_blank" to hyperlink in calculate field gets removed when survey is published
111
06-10-2018 01:18 PM
by Anonymous User
Not applicable
Long story short, I'm trying to dynamically create a link based on answers to previous questions. Everything works fine and the link opens in the same window. This is a problem because if I use the back button to go back to the survey, all of the answers are gone.  I'm trying to use the target="_blank" when creating the url but when viewing the survey in the web form, the target="_blank" has been dropped from the hyperlink. Any thoughts on why this might be happening would be greatly appreciated.
I am creating the survey in Survey123 Connects v2.8.4 and viewing the survey using the web form.
Ian
Reply
