Adding pdf attachment to survey123 (instead of image)
7105
14
03-02-2018 10:44 AM
Jean-YvesLandry1
Would it be possible to attach a pdf instead of a jpg inside survey123 application.  The idea would be to have the person use a camscanner type application then attach the document to a survey.
I can see that it is possible through the survey123 desktop application, however the android survey123 only returns images.
I suppose if the extension .pdf was modified to a .jpg it could work.
JamesTedrick
Esri Esteemed Contributor
Hi Tomislav,
At this time, there is not an update yet.
jonathanrobinson
New Contributor III
Hello, is this feature available now?
PaulCone2
Occasional Contributor III
Hi James,
Any update on whether this feature is maybe coming soon?
Paul
PaulCone2
Never mind, I see it is implemented now.
Media—ArcGIS Survey123 | Documentation
AndrewMcDonagh
New Contributor II
Thank you for posting this update!!
