Adding media to choices in external choice list
3228
13
05-26-2022 12:47 PM
Sarah-CodyKnight
Hi there,  is there a way to add images to choices in an external choice list in Survey123 Connect? I tried creating a "media::image" column in my external choice list .csv and putting in the name of an image in the media folder, but this did not work.
I am using an older version of Survey123 Connect, so that may be it too.
DougBrowning
MVP Esteemed Contributor
Well before linked content came along there were scripts to update the csv instead.  You may be able to adapt that to also update the images.  I do not think linked content does it but not sure.
https://developers.arcgis.com/survey123/guide/update-contents-of-the-media-folder-for-an-arcgis-surv...
https://hub.arcgis.com/content/521168944ace40d0827991eeeba03689/about
https://community.esri.com/t5/arcgis-survey123-blog/updating-the-media-folder-of-a-survey123-form-it...
Hope that helps
by Anonymous User
Not applicable
Did you all ever figure out how to update the media content without having to republish?
DougBrowning
Yes you can use the linked content I mentioned for CSVs.  I use it for our crew lists.  I do not think you can do images though.
Check out https://community.esri.com/t5/arcgis-survey123-blog/work-with-csv-data-in-arcgis-survey123/ba-p/1157...
ShireanRedman
Hi, this post really helped me a lot with including images in my external choice list. I was wondering if anyone else has had this same problem, that it works great until the question's appearance setting is set to autocomplete and the images then don't show?
