Adding a photo to Survey 123 question in connect
635
04-20-2020 07:32 AM
BethanyDavies
I would like to add photos to a series of single choice (yes/no) questions. For example; Did you see a painted turtle? With an image of a painted turtle.
When I add the photos in connect, they are all different sizes and make the survey look sloppy. I would like all the images to be the same size, however, I would like the user to be able to tap on the picture to show a larger image. Is there a way to do this in 123 connect?
OR, do I need to set all of the images to the same size without the enlarging option?
IsmaelChivite
Esri Notable Contributor
Hi. It will be best for you to prepare the images in advance before adding them to the survey. Make sure you test the images too in different mobile devices.  You cannot control the size of the image from the XLSForm. This will be a trial and error process for you. Once you find the right size, apply it to all the images you want to use.
