Hi, we do have a long survey, that most likely will be filled out over a couple of days, while information get's collected.
It has 9 pages, and we don't want to go all the way to the end to log the data in the service. So therefor it will be great if we could get a save button on each page, that's basically is the same as the submit.
We are using the mode=edit&globalId=ID for the survey, which doesn't seem to be able to use the Draft mode. Any ideas to this?
Hello, could you try instead of mode=edit&globalId=ID that it be mode=edit&globalId={GLOBALID}
