Add question to existing Survey
1092
10-10-2018 12:18 PM
JoeBorgione
According to Publish your survey—Survey123 for ArcGIS | ArcGIS  , one can add a new question to an existing survey. I have a simple survey created in ArcGIS Online; how do I get to the design page to add an additional question to my form?
BrandonArmstrong
Hi Joe,
If you published the original survey using the Survey123 Web Designer, you can navigate to survey123.arcgis.com >  to My Surveys > and click on the 'Design' icon for the survey.
If it was published using Connect, you will add the fields to the XLSForm and publish again.
Best,
Brandon
BrandonArmstrong
Hi Joe,
Best,
Brandon
JoeBorgione
Thank you Brandon.  Easy-Breezey....
