Add new field to Survey123 attribute table
1948
03-24-2020 09:25 AM
GeorgiaRoberts1
Hi. I have a hosted feature layer from a Survey123 form in a web map on Enterprise. I want to add a field to the attribute table, without having to add a new question to the survey. Is this possible? I am using Enterprise 10.5.
Thanks very much
by Anonymous User
Not applicable
Hi Georgia,
Are you wanting to use the new field you add to the attribute table in a survey as well, or you just want to use it in other products? If you don't plan to use it in your survey, or the existing survey, then yes, you can add to the attribute table without needing to add to the survey. It just means that field will not be visible in Survey123 Connect or the field, or the web app for users to enter data.
Phil.
GeorgiaRoberts1
Hi Phil,
No I don't want to use the new field in the survey. However I do want users to use the new field in the web app. I am basically wanting users to be able to go into the web app and add comments to survey responses. So I am hoping to create a new 'comments' field if possible.
Georgia
by Anonymous User
Not applicable
Do you mean in the Survey123 web app, or a different web app or web map?
Phil.
GeorgiaRoberts1
Hi Phil,
When I bring the hosted feature layer created by the Survey123 form into a web map, I want to be able to add a field to that layer that doesn't appear in the survey form itself, but allows people to add comments in the application.
I have had a research into this and think this functionality is available in Enterprise 10.7?
Thanks
Georgia
JamesTedrick
Esri Esteemed Contributor
Hi Georgia,
I just checked with a 10.5 site - you can add a field when a layer is in the Map View.  Open it's attribute table and open the 'Table Options' menu.  If it's a hosted service, you should see a 'Add Field' option.
