I would like to access fields that are in a survey's underlying feature service, but are not in the survey.
For instance, get a value from the editor tracking fields CREATOR or EDITOR for the current record from the survey's underlying feature service.
Is this possible?
Hello @CarlBeyerhelm1,
Are you looking to access this information in the survey itself? Are you loading records from the Inbox?
Hi Zach. Yes, within the survey itself.
For instance, when a record is retrieved for edit from the Inbox, I want to be able to make some questions read-only if the current logged-in username is not the same as the original CREATOR. Essentially, this is setting up dynamic read-only questions dependent on the original CREATOR (posted the original record to AGOL), and the current editor.
Thank you.
