We work with high resolution maps and need end-users to draw precise boundaries and angles in the Survery123 form Geoshape question. The majority of our users are submitting forms from their desktop with a mouse or pen to draw the shapes.
Survey123 by default uses the method=sketch, this setting makes the Freehand Area tool a point and drag action by the user, which behaves the same in the field app or browser. Changing the method to "vertex" changes the user action by requiring a point-and-click for each vertex -- but this is only enabled on the field app -- not the browser.
I am requesting Survey123 make the method=sketch available to web browser use.
