We work with high resolution maps and need end-users to draw precise boundaries and angles in the Survery123 form Geoshape question. The majority of our users are submitting forms from their desktop with a mouse or pen to draw the shapes.
Survey123 by default uses the method=sketch, this setting makes the Freehand Area tool a point and drag action by the user, which behaves the same in the field app or browser. Changing the method to "vertex" changes the user action by requiring a point-and-click for each vertex -- but this is only enabled on the field app -- not the browser.
I am requesting Survey123 make the method=sketch available to web browser use.
There is a setting for vertex already. See here https://doc.arcgis.com/en/survey123/desktop/create-surveys/geotracegeoshape.htm
Thanks @DougBrowning. Is this functionality coming to the Web designer?
Also @DougBrowning, I tested changing the default method value from "sketch" to "vertex", while this does allow the user to construct a shape vertex-by-vertex, it does so only on mobile devices; the functionality does not seem to be available for users entering a shape on a form in the web browser.
I am specifically seeking the vertex method to be available to users in the web browser.
The following animation shows the use of the Survey123 vertex editing tools in a web browser:
To enable vertex editing:
