Survey123 Connect translate submit button
499
10-06-2020 12:19 AM
Status: Open
AndreasLorentzen
New Contributor III
As there are no way to use a costume map in the Survey123 web version, so started using the Survey123 Connect. However, the only thing that holds our organization from using it widespread is that our costumers demands that all text should be in Norwegian.
The only thing missing is the submit button. It can be changed if you are using the web version but not the desktop version.
The idea:
Make it possible to to change the text on the submit button in surveys created with survey123 Connect. Either online or in the desktop version.
or. costume maps in the web version
1 Comment
AndreasLorentzen
This idea is now obsolete. As it either was possible the entire time or has been implemented later than i posted this.
you can do this by
Adding a note with label "Submit", with label::language(no) used, and then in the settings tab add that to the default language.
