Support Popups in Survey123 fieldapp
738
01-12-2022 07:11 AM
Status: Open
Labels (2)
chelynnes
New Contributor III
On multiple select ideas, there should be a popup or hover option implemented to give users more info about the question or selections without cluttering up the form with text permanently.
For example, click a question mark button and have instructions or explanation populate.
1 Comment
DougBrowning
Have you looked into the Guidance hints?  They are too small IMO but may work for you.
See this post  https://community.esri.com/t5/arcgis-survey123-ideas/survey123-tool-tip-pop-ups-in-the-survey-form/i...
What I do is use images for each option like this.
Hope that helps
