Support calculating geometry from select_multiple choices inside repeats in Survey123
593
01-13-2026 12:42 AM
Status: Open
Labels (3)
Chalhoub
In Survey123, a common workflow is allowing users to select multiple locations or areas (for example, administrative boundaries, service areas, zones) and automatically populate the geometry for each selected item inside a repeat.
This is achievable today using calculated expressions, but the approach is advanced, undocumented, and fragile, making it difficult for many form authors to implement correctly.
Current working pattern
The following XLSForm structure is used to calculate polygon geometry based on each selected value from a select_multiple question:
type name label repeat_count calculation appearance
select_multiple location_listselected_locationsSelect all applicable locations  horizontal-compact
begin_repeatlocationsLocationscount-selected(${selected_locations})
calculatelocation_code  selected-at(${selected_locations}, position(..)-1)
geoshapelocation_shapeShape pulldata("@layer","getValue","geometry","<feature_layer_url>", concat("<location_id_field>='", ${location_code}, "'"))
end_repeat
This pattern relies on:
  • count-selected() to dynamically create repeat instances
  • selected-at() with position(..) to map each repeat to one selected value
  • pulldata("@layer","getValue","geometry",…) to retrieve geometry from a feature layer
