Stop domains during data synchronization from Survey123
204
03-22-2018 03:52 PM
Status: Open
SainiGurminder_Singh
New Contributor II
Survey123 is meant for field data collection using set parameters and coded values (in the form) and final database stores the collected values. While synchronization to ArcSDE or FGDB it exports the data along with set domains , which is a big hurdle to synchronize data to pre-existing database because there is no way to add a domain to a connected (locked) sde geodatabase schema.
Even if you export survey 123 data to FGDB, domains comes along.
As an end product, we don't want to see the domains as long as the field values satisfies the survey collection.
I am struggling to synchronize the data and see this a major issue.
There should be a way to block the domains.survey123 attachments#
