Right now you can insert a map into a report and set a fixed scale. This works great unless the geotrace or geoshape extend beyond the scale. It is possible to not set a scale however smaller geotrace, geoshape or geopoint questions may not include enough surrounding map context to be valuable. If you could set the minimum scale (or inversely, max scale if you don't want to zoom out too far) that would be a great help in providing the entire geopoint/geoshape/geotrace question and any valuable surrounding map context.
