use Default or Calculate field in Survey123 Connect to set a default filename for images captured in the survey123 field app. Rather than the what is set by survey123 (a garbled mess that you can't easily sort back in the office after exporting from the geodatabase) you could use a calculation such as concat(${question1},format-date(${WSDateTime},'%Y%m%d%H%M',".jpg")
