Select features in survey 123 website with polygon/box
626
03-17-2023 05:05 AM
Status: Open
ChristopherDawe
It would be great to be able to select multiple survey submissions from the map view in the Survey 123 website using a polygon/box/lasso select, to then print reports for these surveys. Currently you either have to select the features individually from the attribute table and hold shift/CTRL to select multiple ones, or apply filters to the data to get the selection down to the ones you need for reports. If the survey doesn't have fields to allow for suitable filters it can make selecting things quite clunky, additionally unless the survey is filled in exactly correctly you can also miss features using filters.
