2x ideas -
1. define a certain question to scroll to on NEW repeat records when a user clicks the "+" to add a new record.
2. Flag to expand/collapse/use XLS Appearance setting for groups within repeats when the user clicks "+" to add a new record
Right now, the vertical scroll defaults to the bottom of the repeat when a new record is added and any groups that were expanded in the previous record will remain expanded on a new record. Having the option to overwrite each of these behaviors individually would be great, but being able to set the behavior for the entire form would be very helpful as well.
