Pass XY from feature in Collector to Survey123 form
4777
12
06-23-2017 08:04 AM
Status: Open
GISAdministrator22
Would it be possible to pass the XY coordinates from a selected feature in Collector to a Survey123 form?  My current workflow entails selecting a feature (inlet, manhole, etc) from within a collector app and opening the associated Survey123 form through a custom URL to perform a field inspection.  It would be very beneficial to have the Survey123 point be in the exact location of the feature being inspected instead of relying on device GPS (although GPS is sometimes necessary).  I am referring to the inherent location instead of values from  X and Y fields, as this requires unnecessary overhead, i.e. auto-populate Geopoint values with coordinates passed from selected feature in Collector.
12 Comments
Carl_Flint
James & Mike,
You were both very much correct the precision setting in the popup configuration was set the the default 2 decimal places and setting that to max helped greatly.
Thanks.
JamesTedrick
Hi Christine,
The version of Collector that supports this has been released on iOS, though the web map used in Collector needs to be in WGS84 coordinate system.
