If someone updates a survey in the inbox and another user goes into the inbox to update the same survey without refreshing first, the survey does not have the changes from the first user.
Can a slider be added to in Survey123 Connect (Settings/Options) so that in certain surveys when a user opens the Inbox a refresh is forced to avoid the problem explained above.
Cheers
This would be super helpful, I rely on the Inbox for a QC workflow and to send forms back to users for revision. Forcing a refresh to always have the latest version of a record would save some headaches.
