It seems a web browser submission of a survey differs from the preview you see in connect under "Form Preview". With a public facing surveys I assume most are going to be completed in a web browser.
For example masks work perfectly in the preview window of connect, however if you publish this and complete the survey via a web browser the functionality is lost.
It would be great if there was a setting on the preview window of connect to get it to display and act as it will in the web browser. Otherwise the only way to really test a survey is to publish it, make changes republish.
This would be a big time and frustration saver!
