After scrolling through older posts and running into this issue myself currently, I think having the ability to modify the button size on Survey123 would be a huge improvement.
The small buttons may work for most people and projects, but some field workers need to collect their data very fast - the bigger the button, the easier and more accurate their job becomes.
Why not Quick Capture?! Quick Capture is great and has the big buttons field data collectors need, but is limited in comparison to the functionality Survey123 has. I cannot perform the analysis I need to do with Quick Capture.
You can make controls bigger through App-Settings-Text as shown in the animation below
