Enable Feature Reports in ArcGIS Enterprise Portal
1028
06-16-2020 12:11 PM
Status: Open
CTTrafficOps
The current limitation: "Printing using feature report templates does not work with ArcGIS Enterprise deployments that aren't public facing. Attempting to do so will present a getaddrinfo ENOTFOUND error."  Found here.
However, the sensitivity of the data I work with can only stay in Portal and the end result of a Feature Report is preferred over the non-formatted print view when clicking on an individual report within Data.  Would you enable Feature Reports in ArcGIS Enterprise?  Also since Feature Reports is not an option in Portal why is it enabled and why is it even there to begin with?  This creates confusion for the user and requires time wasted in digging around for a solution when there isn't one.
2 Comments
Aneel_Kumar_M
Hello everyone
any update on this ?
We have similar issue. Please help, if there is any solution.
thank you,
ToddW_stl
@Aneel_Kumar_M - it's been awhile since your question, but no updates.  I've posted more info from my brief investigation with a potential workaround here.
