Dear Esri Community - Survey123,
@IsmaelChivite @ZacharySutherby
I found that when using choices from layer for a Dropdown control on Survey123 currently have limitations that can be improved.
First, you cannot uncheck Appearance --> Autocomplete anymore. Please allow disabling Autocomplete please.
Second, you cannot Set Rule(s) for conditional "show" other form control based on "If" select choice then "show" anymore.
These features mentioned above especially the "second" one needed to be improved to make Survey123 more powerful without using Survey123 Connect.
Thanks a lot,
Reno
