Copy survey from inbox
685
10-22-2020 11:39 AM
Status: Open
AndréEmond
New Contributor II
J'ai la modification suivante que je voudrais faire apporter a Survey123, concernant l'enregistrement des enquêtes en mode hors connexion.
Une fois l'enquête enregistrer dans la boîte d'envoie, Il faudrait avoir la possibilité de copier les données dans une nouvelle enquête. Comme il est possible de le faire à partir des enquêtes envoyées !
Google Translate
I have the following change that I would like to have made in Survey123, regarding recording offline surveys.
Once the survey is saved in the outbox, it should be possible to copy the data to a new survey. As it is possible to do from the surveys sent!
1 Comment
wxsouth
I second this enhancement. Many of our surveys begin in areas lacking data coverage, and our surveys often involve collecting similar data at different locations. Being able to rapidly collect similar point while offline would be extremely helpful. Only being able to copy to a new survey from the 'Sent' box is limiting.
